I have no sound for text only on my samsung S8 , can anyone help?
  • Start date Start date
Select a different notification for texts.
If that works, the file you were using for the notification is corrupt. If it doesn't work, there's something wrong with your text app.
First case - there are thousands of notifications at ZEDGE (even a few takeoffs on AOL - they say "You have a text").
Second case - there are dozens of 3rd party text apps at the Play Store. Choose one of the free ones that you like.
KidColoringPage
