I have problem with usb connection.
edib
4
Hello androidcentral members.
I have Galaxy S4 device and i have one mistice problem. When i connect Usb cable to the PC my device charged OK but Usb connection not work, but when i go to download mode ODIN connection worked good. I reinstall 3 times OS , 1 time official OS and to times Rom OS but problem not solved.I trie to reinstall drivers to PC but not work. When i connect AC Adapter on electricyti devide charged ok but on display not notify anything.
Thanks and Respect.
Try to activate the USB Debugging at the developer Options. Maybe you get a connection with this setting.
Not work :S . I think is soft brick but i dont now how to solve this problem.
Do you have the option to use another USB cable? Heared about it, that the USB cable can disturb the data connection. Try it with another cable.. maybe it helps
