I installed CM7 and now my Nook Color will not leave rcovery
Clon
Yesterday I installed CM7 on my Nook Color, now it will not boot into CM7, but continues to boot into Clockwork Mod recovery. I then tried to put the stock Nook firmware back on the device, but that will only go into clockwork mod as well. I was wondering if there was anyway to fix that, or if I just fried my nook.
Bootable SD card
Did you remove the formatted SD card that you used to install CM7? That SD card was formated to boot the nook into CWM, so if you attempt to boot the nook with it installed, the nook will boot from the SD rather then booting into CM7.
Rehan10w
