I made a mess, can I get some help cleaning it up?
ipeefire
I made a mess
so after I upgraded my galaxy s4 GT-I9500 to lollipop 5.0.1, I didn't like it at all and wanted to return to kitkat 4.4.2, so I went on Sam****** and found the firmware for my device and country, used odin to flash it (is that the right term?) and after everything succeeded, it won't "use" my sim card. and in bottom of notification panel it says "no service" and I'm not able to make any calls or connect to wifi. I did some googling and found out that the EPS folder is corrupt? and IMEI is null? and the fix is to reflash with lollipop it seems. I'm currently downloading lollipop firmware but I'm not sure what I'm doing right now :/
Osivourough
