You can put several app icons in one folder / tray in the home screens, or in the dock on the bottom, if that what you mean.
Interesting! How do you do that ? Inquiring minds would like to know!
Sent from my Samsung Galaxy Note 3
"Size Does Matter!"
You can do that with Nova.
App drawer / list - menu - create folder - rename folder, find empty folder in app drawer, drag icons in, move to homescreen (drag down to dock).
http://img.tapatalk.com/d/14/06/28/4ymave6u.jpg
http://img.tapatalk.com/d/14/06/28/epyze4u5.jpg
Sent from my SM-N9005 using Tapatalk Pro
Now I have learned how to create an app drawer (and I did) how can I remove apps from the drawer without deleting them?
"Size Does Matter!"
Assuming you are talking about apps in a folder, not the app drawer, if you're using the stock launcher. just long press on the app and drag to the top of the screen to Remove.
Got it! Thanks!
"Size Does Matter!"
Yes you can. When you edit the folder you just choose the other folders you want in it.
Here, you can see I just made a My Folders folder and put all my other folders in it.
I'm trying to do this exact thing on my note 3. How do I initially create a folder like what you've done with "My folders" on my home screen and then place folders of apps within that folder?
The amazing Note 3!
First, you have to install Nova Launcher and set it as your home launcher.
Then, in Nova Settings, go to Drawer and then Drawer Groups.
Click on the Folder tab and click the + button up top to create a new folder.
Then click on the folder you just created and place a check mark next to the folders you want in it.
Exit or back out of the settings and go to the app drawer.
Long press on folder and drag to homescreen.
I do not believe that is possible.
It seems just can move icons into 1 folder...
Ok I've done all of that now thank you so much! My only problem is the folders I have on my home screen were never created through the app drawer in Nova settings, they were just created by dragging and dropping one app on top of another on the home screen and it automatically made a folder and I would just add to it and rename it from there so none of those home screen personalized folders are in my drawer section in Nova Settings so I have to make them again lol
The amazing Note 3!
