i need help I factory rest a custom rom on my lg esteem
johnchambersj
4
I need help I factory rest a custom rom on my lg esteem and now all it does is go to clockworkmod recovery and if I hit reboot it just goes back to clockworkmod recovery can someone tell me how to fix it please
Flash the same ROM again. Did you perform the factory reset from recovery or from the settings?
You have to do it from recovery any time you have a custom ROM. Try flashing it again and see if it works
i tried flashing the same rom and it says no file found and I press reboot system now and it goes back to clockworkmod recovery
What happens if you flash the stock ROM?
Abheetha Athukorala
