i need help! please!
ChiefYolo
Active member
Apr 29, 2016
29
So whenever i install an app from the Google Play Store,it wont show up on my app drawer,i need to reboot it then it shows up...help?
Welcome to Android Central! Which phone? Did the phone come with Google Play Store preinstalled, or did you have to install it manually?
Copy the URL in my previous post and paste it in your browser. Sorry, but I couldn't put the actual link in the forums, because for some reason certain Verizon URLs don't link properly here.
Safe Mode temporarily disables all 3rd party apps that you installed. If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
Bob230
