I need help with the mobile hotspot
MaxEvans
10
I changed the ssid and password, But now Eventing can't connect. What am I doing wrong? I do this on routers and it works fine. But not on my phone.
Welcome to Android Central! Were you able to connect other devices to your phone's hotspot before you changed the SSID and password? If so, then make sure you forget the network on the devices you're using to try to connect to the hotspot, then connect again and enter the correct password.
If it has never worked for you, then are you sure your data plan includes hotspot usage? It usually requires an extra fee (or more expensive plan).
Yes it worked before I changed that. Credentials. But after I changed them, my laptop says it can't connect, and my tablet never connects.
I got it working I tweaked with the settings and got it. Thanks for the help.
boone
