I need help!
jordysr
5
While trying to install the new Vegen GE ROM I somehow ended up bricking my tablet. I followed the install instructions I found on the XDA site. Everything was going well till I rebooted the tablet to load the new ROM. The instructions said it should take around 15 minutes, after 30 minutes I stopped it. I then set the SDA numbers to 2048 & 0, rebooted & nothing. I tried to do a recovery & it said no file found. I tried to reload the new ROM, it said no directory/file found. I connected the USB to my laptop to push the ROM over again, and it never recognized the tablet? What now?
I'm not sure if I tried that or not. I'll give it a go tonight. I went through many options & reboots last night. I'm to also try the 'Fix Permissions" option tonight. I did use the instruction sheet that you posted. Right now all I can do with the gtab is get into clockwork, I'm pretty stuck.
Thanks for you reply.
kimlien
