Can someone solve the problem of having duplicate Cell phone numbers for a contact
If their cell number is 555-555-5555, Then when I want to send a text, the numbers would show up like:
Joe Smith (m) 555?555?5555 (With the "?'s" in the number) and a 2nd one
Joe Smith (m) 555-555-5555 (where this is the actual number)
It messes up the voice dial and I have to watch and make sure I pick the correct name and number when I text, cause the wrong -one with the "?" won't get sent.
when you text, if I am sending joe smith, it will start to show the names with J, then jo, then joe, then joe s...etc. and when u get to the one you want, YOu can select it. Well, I can't use that feature, cause when Joe smith shows, it may well be the second Joe smith , without the "?"'s
Thanks so much
I thought it was numbers on the SIM card, cause I used a app to copy numbers on there, but I deleted them to problem solve, and the problem still exists.
Please. You don't know how much your help is appreciated.
Eric
Thanks so much
Eric
