ice cream update
While installing the update my phone died. After charging enough to turn on the phone goes into boot loop. I went into reset, booted up again now makes it all the way to "activating" screen then shuts off again. Any suggestions on a fix?
So far impressed... although most of my settings went back to default like file associations, screen brightness, contact links, but minor stuff. Interestingly no power or sleep profiles anymore, or am I missing them somewhere?
oh, this is all kinda sexy. So far... happy. Just waiting for everything to finish updating and installing. Gmail is so much sleeker. Love it. But it's all going to take a little getting used to.
I noticed that the LTE on off widget is giving me different menu options. I hope that I can still use this phone in Akutan, Alaska in gsm mode with my Alaska Wireless sim card.
Sent from my ADR6425LVW using Android Central Forums
Just installed the update, if you haven't updated yet or are in the process of updating, BE PREPARED TO WAIT! There's 2 updates, the 7.1mb update then the 299mb one, after that it goes through a thing where it says Android is updating and it goes through every app installed, every contact in your people's app, and all the system files (takes about 5min) but after that its awesome! one more thing to note, it seems the update changes all personal preferences including ringtones (it even deletes all personal ringtones), etc.
*facepalm* Never EVER do an update with low battery. It will corrupt the system like it did here.
Try this: [Exclusive Download] HTC Rezound Ice Cream Sandwich RUU For Final OTA (3.14.605.12)
Make sure you follow instructions.
Reactions: NightAngel79
Anyone know if a phone has the bootloader relocked, and was RUU'd, would they still get the update?
Just for you guys ;) left the cool office and went out in the 110 degree heat to check the Rezound to see what was going on (mobiles have to stay in the vehicles).
Gave the okay to download then install the phone update, and now it's on the ICS downlaod screen, but not doing anything.
Now I can use the phone but not data, not unexpected.
We'll see where it's at after work.
Change Log? I check the VZW site and the other forum that Phil started. Its still showing the old changelog . Can someone post the PDF?
I wonder if they fixed the gsm sms sending problem. I heard that they would, but I won't be able to tell until the end of August.
What's the difference in .10 and .12? Should I bother? Changelog?
Git my Rez in May. Thought I'd be closer to the end of the line. Woohoo!
deevencoo5
