ICS 6.7.230
  • Thread starter Thread starter Ry
  • Start date Start date
Yep, running smooth here, gps and everything. If it's not the final ota, gotta be close!
Sent from my DROID BIONIC using Android Central Forums
It would seem likely unless a major issue is found. I'm very happy with my phone as is now.
I was told to update the thread again. I've attached the script as a txt file that can be downloaded and renamed. Should make it easier.
I'm going to use your script, thanks for sharing. I'll tell you how it goes.
The script is awesome.
Absolutely awesome. :)
Great job man, the script is incredibly helpful.
What you should do is at the beginning of the script is remind the user to put the two updates on their phone, the .905 and ICS updates. I almost forgot beforehand, but luckily I read over your instructions first.
LOL! Yes, ICS 4.0.4 and razrs edge root. It's a very nice combination IMO. :)
Good suggestion. Script is updated. Thanks!
Nice man, good luck with the new package.
Heck, if you really wanted to, you could make the script push the files and then use ADB to turn off the device so they can turn on fastboot. I completely forgot that I had to be in fastboot at first (for some weird reason) to flash .902 and was wondering why it wasn't working. Then I figured it out and felt like an idiot.
ROFLMAO. You really should take a look at the very latest. ;) I do way more than that. :)
Could someone please direct me to a thread or site that explains the process of installing ICS? I've been trying to follow several processes that require Safestrap, but the Safestrap apk refuses to install giving me a parsing error. A few others have complained of this problem but noone has ever addressed it that I can see.
Anyways, I'd appreciate being pointed in the right direction...
And just like that 232 is now out. I'm away for the weekend so I can't test it.
Sent from my Xoom using Tapatalk 2
Reactions: Ry
gianfranco
