ICS 6.7.232
  • Thread starter Thread starter Ry
  • Start date Start date
Stupid question then. Did you use something like Titanium Backup to restore system data the first time?
Quick question. Will this Runme work coming from OTA 905? I downloaded the update when it was released. My phone now is 905 with forever root.
Sure it'll work on 905. It should undo the forever root mod for you. The only thing that seems to have caused people issues is if they have safestrap installed. That appears to do something to the data partition that we don't touch, that causes problems.
Sent from my Xoom using Tapatalk 2
I have a quick question...are you guys able to change the wallpaper from your gallery or live wallpaper and it stays that way permanently? I cant understand why my droid bionic doesn't let me keep the wallpaper I want. It keeps reverting back to the stock wallpaper which I am sick of. Its my phone so why I cant understand why I don't have that option.
If it's any consolation 235 seems better on battery life. So whatever the OTA ends up being should improve things.
I was checking out some different threads on droid hive. Process seemed pretty clear. However I was curious and wanted to clearify something. I now have TB installed. Once I have flashed ICS and rerooted I will NOT beable to apply any back ups created prior to ICS?? Correct? I will be starting from scratch and all my backed up apps and data will not be avalible??
Thanks for the help.
PS I do not have safestrap.
Tb is fine so long as you play by one rule. Restore apps and app data but never system data. And I would personally wipe cache and Dalvik after restoring the apps and reboot. An android upgrade script will then process your apps. Let that run and when fully booted after that reboot one more time.
Ok I'll give it a try. I am now running 232. I am having issues restoring any apps let alone system apps but I'll stay away from them. I used the method on Droid hive. Wiped data before install of 232.
I'm having other issues with the OS its self. The screen lock won't work at all. Also the home button doesn't work at all. No matter what I am doing the home button does nota.
Sent from my DROID BIONIC using Android Central Forums
Those issues only happen when you restore system data. I'm not talking about system apps but the system data itself. You'll need to wipe the cache and if that doesn't work you'll need to factory reset it. That will fix the issues.
Got it. I was having a PEBCAK moment. I wasn't seeing all of my apps to restore. I never took off the filter. Duh.
Ok I'll wipe the cache. Factory reset fixed the issues. Thanks again.
Quick question. What exactly is the Cache? I booted into recovery then wiped cache and factory reset. I was just wondering what the Cache was? Thanks
Think of the cache like the temp directory in windows. It's just temp data used by your apps. More or less.
OK that makes sense. Thanks.
kitlis
