ICS and JB reboot randomly. Any ideas?
I just moved it to the left side of the screen.
Tapatalk'n it PAC-Rom style! Android 4.2.2 on my VM670 running LS670ZVJ firmware
I could also note that I flashed EarthnFire78s rngd-urandom-tool and redBarrons amphetamines.
I remember seeing Earthnfire78's tool mentioned, but where? Could you enlighten us please?
I would never had thought to try Amphetamines on a JB ROM, but I guess I'll have to now.
Do you think being on the ZVJ firmware has given you better performance with the PAC ROM, then if you where on ZV4 or ZV5?
I don't think zvj has helped performance wise but i haven't experienced dropped data and I don't have anything else to compare with. Before EarthnFire78s tool entropy was 250-300 via a checker on play store. Now it's around 4000. Amphetamines I'm not sure how much it's helped.. Didn't break anything though.
Edit: rngd tool
http://forums.androidcentral.com/showthread.php?t=247037
Thanks.
By the way......hows the updated guide coming along?
Thanks.
Put it on the back burner... Just haven't had a lot of time and I think a lot of ppl will have trouble with setting up lgnpst.
It was pretty easy for me, and I really struggle with new stuff. Your going in the right direction. Now put your foot on the gas.
Anybody have UI problem or fix idea?
PS: To thewraith420. That definitely got my entropy value up. It went from a measly 150 something to over 3500.
I just closed out a ui fc.. For me it is pretty infrequent though and the ui comes back in a few seconds.
I just keep getting the pop-up, with no background or status bar either.
All I had was a quick fc, the notification bar disappeared then came back didn't fc again and I just went on with what I was doing. Waiting now to see if it happens on the newest build.
I recently had an issue where the ui was gone, but notification bar stayed... I was sitting in a bar reflashing under the influence :/ FYI, not a good idea...
Duh! Lol.
And I thought I had the flashing sickness bad. I ain't got nothing on you.
..... Wow... That bring a whole new meaning to the word flashaholic... Lol
I would go to more bars if my wife and friends would leave me alone to flash ROMs.
Sent from my GT-P7310 using Android Central Forums
Figured out what was causing the UI FC's. There is an option to resize the dock icons. I was resizing them to fit the screen.
Now I just have to download the SD ext script. Doh! Totally forgot. Was installing my apps before I realized it. Got the low space warning. Light came on, bell went to ringing!
Let me clarify, i lost the ui after a crash... I didn't choose to flash under the influence, i just needed a working phone... I. Did observe my very first boot loop that night though :o
How can i see what size my sdext is set to?
Link2SD.
Menu/Storage/scroll down and there it is.
Warning: Flashing under the influence may cause phone to crash or boot loop. Lol
SADdfgf4567
