(ICS)CM9, Now 3g!
I think one of my previous posts covered your problem you have right ROM just need to try going into the phones test screen *#*#4636#*#* on the dialer screen to access then phone info scroll down turn off radio turn back on then try toggling data option normally should work at that point and yes if that worked then every time you boot you will have to do it again until a permanent fix comes along
I tried that and it dialed and I got a recording saying this menu feature isn't available or something, but after toggling airplane mode and rebooting 3G is working. Just need to do the file swap for the homekey fix.
Also tried to uninstall the stock music app and replace with google music 4.0.1 with no luck. I tried like I do with BACKside, uninstall the stock get the apk not found message, reboot, restore 4.0.1 with titanium wait about 20 minutes for it to say it is done restoring, reboot and use.
It now shows the stock app with the 4.0.1 icon and that 4.0.1 isn't installed. When I try and download from the market it says the apk is not signed correctly and to uninstall the other version first.
Working on my own version of tdm's port as well. Hopefully with my own modified gapps. Looks like a lot of sideloading to do for me :)
Reactions: notown
Add the volume controls back to the menu for holding the power down, please? :)
Also, Home and Menu keys are misplaced.
Sent from my LG-VM701 Gelato 11-28 via Tapatalk
Works great! Couple wonky things. Email. YouTube. Red box around screen when checking a box. Browsing the web works great. The entire environment of it is great. Wish the dictionary for auto correct was there lol.
Sent from your mom's phone.
Sorry, what do you mean with the volume controls?
New build will have the keys fixed.
Reactions: mustafu
It used to be that when you go to the power menu, you could choose sound, vibrate, or mute. Identical to this pic I will upload in a sec :)
Sent from my Amazon Kindle Fire using Tapatalk
Yeah, this is what I meant, sorry I wasn't specific.
So far it looks great, I'm looking forward to the updates :)
Sent from my LG-VM670 running IHO MiRaGe using Tapatalk
Reactions: mustafu
Dead links?
Quattrimus has been updated more recently than this rom, which would likely explain the dead link. AFAIK people working on quattrimus are browsing the community and pulling together all of the fixes and updated repositories they can for the next release. Then after that maybe LeslieAnn will create another version.
The download link is dead. I don't want to filter through all the pages to see if there is a new link for the cm9 download elsewhere. Anyone?
Download links are now in TDM's thread. This was never a project, it was just a reference basically.
Go to TDM's thread and download there.
Ishimwe
