ICS: GPS, Bluetooth and Wifi Issues
ebookof
8
I had many issues after the ICS update. I finally had to factory reset the tablet. It solved some issues, but several issues remain:
Seems to be solved:
- Unstable applications (flashing and crashing, including Gmail).
- Unstable folders (flashing, crashing and all icons on the desktop disappearing).
Unsolved:
- The GPS does not work (this is a new issue I had not noticed before; I am not sure if it is related to ICS, since I have not had my tablet for a long time and I had not tested location through the GPS; I have tested recommendations in forums, but they did not work).
- Wifi is unstable (the strength of the signal varies constantly; it disconnects; it does not connect automatically when I arrive at home and activate the device; this is a new issue since ICS).
- Bluetooth is unstable (it disconnects me regularly; I have to turn Bluetooth off and back on for the devices to connect again; this is a new issue since ICS).
Anyone else with similar issues? Any solutions?
I would pop on over to XDA and download the official OTA and install it cause I have no issues like you describe. You might have gotten a bad install from the original OTA causing your problems.
vickyy
