[ICS] ICS Leak 4.0.4
So why do all the instructions say to download the .7z file?: IMM26.7z (Contains Kernel For ICS Wimax IDK Stuff), then not explain what to do with it?
The bottom line is that you have the new kernel if you used Odin with the three tar files. If you unzip all the files and look at what's inside what do you see?
Sent from my Nexus S 4G
Anyone know if ICS 4.04 fixes the ability to have your phone recognized and viewed as a device in windows 7???? This is a bunch of crap not being able to transfer picture/ video files on this POS phone!
Thanks!
Thanks!
Running Windows 7-64 bit, don't have a problem at all....
Try grabbing PDAnet for you computer and allow it to install the app & drivers on your computer. This should help make the connection work.
Thanks!
The ONLY way I can transfer files via USB it's by disabling USB debugging in the settings. This MUST be done prior to connecting to the PC. That is the only way my phone can be picked up as a drive. Using pda net gives me a positive connection but doesn't let it become removable drive as you must have usb debugging on with pdanet.
Like I said, turn off usb debugging and see how it goes. If it doesn't find it then. You don't have the right drivers installed.
____________________
Just Flash It !!!
I can't seem to get into ODIN download mode on the device. Running custom ICS rom currently. Holding down both VOL UP+DOWN then tapping power just boots the device. What am I missing?
EDIT: never mind I'm a moron. Was pressing power too long.
Reactions: evansgw
Is your bootloader unlocked already?
I am still having problems... grr
So what's the story? is the 'leak' still wreaking havoc with the proximity sensor and wifi? is it just happening with a few folks or is it widespread?
I have the proximity sensor issue but it's not even that big of a deal. Wifi works perfect for me though. I flashed the latest radio.
Hay Paul I have another Brain Tickler:
Say I rerooted my phone and installed the leaked ics rom and restored all my previous settings and data. Now could I use BWM to back up a copy of that data, unroot and Odin install the leak and use BWM to restore my settings?
I was wondering if this was a work around for those that wanted the update now but wanted the OTA when sprint releases it. Like a best of both worlds :)
alrighty ive come to a little snag, heres what i did:
1.i used BWM and made a back up
2. i restored my phone back to gingerbread stock(still rooted)
3. used one click nexus s root ver 3 to unroot my device
4. checked to see if i still had data (app data) then i confirmed i was unrooted
5. started odin
6. pulled battery, held volume up and down then clicked power. this then brought me to the "unlock bootloader?" page with no options on the bottom. i seen that it wasnt the download mode, so i battery pulled a couple of times and no download mode, but i thought i would try to continue anyway
7. connected nexus to computer, pc recognized the connection but odin doesnt
so yeah... thats where i am, kinda stuck. if you can help me out i would like to continue to try your BWM suggestion
I had this same problem. I used the one click root process only to the point of unlocking. Then I closed the script and started Odin... phone went right into dl mode and the Odin process went smooth as silk.
Yes I think so. With the BWM as long as your backing up and restoring on ICS your fine. The actual backup data resides on your computer so that is safe. The data that is being backed up is only that, data/settings... No actual system files are being saved so there shouldn't be any worries about conflicting ICS versions.
Anyhow it's worth a shot, probably work
Sent from my Nexus S 4G using Tapatalk
Rooted and flashed.
Loving ICS so far. Had a couple of random restarts, but the radios seem stronger.
I'm still having a problem with Odin.After re-rooting my NS4G I was finally able to get into download mode. I reinstalled pdanet and Odin, but Odin doesn't see my phone. Oddly, my pc recognizes my phone when connecting my phone. I want my phone ICS'd but I don't really want it rooted
<ID:0/003> Added!!
<ID:0/003> Odin v.3 engine (ID:3)..
<ID:0/003> File analysis..
<ID:0/003> SetupConnection..
<ID:0/003> Can't open the serial(COM) port.
<OSM> All threads completed. (succeed 0 / failed 1)
thats what i keep getting what can i do to make it work ?
For those whose NS4G isnt recognized by odin, you might want to download and install the android sdk provided in the "how to root" section provided by Paul627g. I was having major problems with this last month, and i already installed pdanet. Just install sdk, and download/update all the samsung device files. After that odin was able to see my NS4G. I've been running the leak and its really great, I just have phone proximity issues. :cool:
My NS4G still is not recognized by Odin... and I have I believe I have all the samsung device files updated... any ideas?
EDIT
So got Odin to connect but for some odd reason no matter what when I try to write a new system I get stuck in a forever hang time! What can I do to fix this?
brucestark2741
