ICS Leak eatting battery?
I'm new to all this root stuff. I just did the BAMF ICS leak by following the directions on this site. If I was to try one of these other ICS versions, where do I go to get it and are the instructions any different? What about radios? If a different one is needed, how do I know which one to get and where do I get it?
I've also noticed worse battery life (use extended battery), excessive lag time, and the data network keeps dropping off.
Look here for Jester's versions of ICS (Liquid Desensed and Liquid ICS MR 2.6 Beta)
Thunderbolt Android Development - xda-developers
The MR 2.6 ROM only has 3G right now, but everyone loves it. The other one is just like it says, a desensed version of the leaked ROM that BAMF released. The Desensed ROM works well with .9 and .19, but the BAMF leak has the least amount of problems with the .19 radios. If you're using the .9 radios, make sure you don't turn on bluetooth or your phone will go into a boot-loop on the BAMF leak based ROMs. To find out what radios you're on, go to About Phone, the Software, and then find the Baseband Version. The .19 radios are 1.49.00.0406w_1, 0.01.79.0331w_1.
Reactions: F350-6
Just an fyi to everyone. There's a leaked radio over on rootzwiki. Its getting mixed reviews, but I'm on it and its as solid as .19 or .39 and my bolt is way snappier/faster with it. I still have to toggle data off/on when I force it to cdma but I had to do that when I was using .39. Its definitely earth a try.
sent from my bolt using tapatalk
Thanks. I'm on a .19 radio so I guess I'll go search for the MR 2.6 ROM. I can live without 4g, but do need bluetooth.
Put a fully charged std battery in 6 he's ago and still at 70% running liquid ics. Seems like good battery life to me
Sent from my ADR6400 using Android Central Forums
Will you keep us posted because I personally don't think it monitors it properly. It will jump way down, sit at a % for a long time, etc, etc. One night mine dropped 30% and the next night it dropped 55%. Both nights it was during 6 hours in airplane mode with no use.
Does your CPU actually ever go to sleep?
soraplzzzzz
