ICS rumblings for Razr??
The problem with just installing the .211 leak already is that piggy backed on the official update is the update that turns your phone into a world phone.
And who knows if there are other fixes. Just cause its the same build number doesn't mean its the same
Sent from my DROID RAZR using Tapatalk 2
I've been playing with it all morning, definitely a little different....without a doubt faster oh and here's the screen shot
Sent from my DROID RAZR using Android Central Forums
You really know you are a complete geek when you check for the update more than three times in an hour. I need a life!
Reactions: bed269
I didn't check for it....it was actually already there this morning I just had to agree
8:32 PM Eastern ....nothing....yes...I am a geek... anyone had success in their part of the country yet? Virginia here....
From what I've red, it's a push notification no need to check
I scream you scream we all scream for ice cream.
I want it to I miss it I had it for 3 months and when I got this maxx I lost it. But at least I have a phone that I can actually use now, so I can wait.
I don't care what kind of phone you use, that's not how I judge someone's worth or intelligence. Sent using tapatalk 2.
the update is not coming untill the soak is over. Soak will probably be over monday, then tuesday or wednesday the update will start rolling out
They're the same. Or, if they're not, Motorola just happened to compile a slightly different version with the same build number, on the same day, and at the same time as the previous leak. :p
I know people that have already gotten it.
Sent from my DROID X2 using Android Central Forums
Not true. It seems that they are pushing it in small numbers concurrent with the soak. People that have not signed up for the soak have received it.
I have started a new thread .. Eastern NC Got ICS?? have a good cross section of the US not just NC over there that have not gotten ICS... Sound off if you do or do Not over there!!
kskiles
