ICS Today?
I have it now but don't see a lot that's changed. What are you guys seeing that's new?
Google voice typing seems 2 work but is slow and doesn't recognize every word correctly...that was done using it.
Sent from my Transformer Prime TF201 using Xparent Blue Tapatalk
Never noticed the ASUS task manager widget before - is that new? Seems pretty awesome. The fonts are noticeably different. The pattern lock screen is slightly different. This is exciting! :)
There are so many things that are slightly different. Even just clicking the search button on the top left seems nicer :)
Anyone find/get face unlock to work? I can't find it in Settings... Don't really care if we have it or not, just curious
Anyone else having bars appear across the screen if you don't click anything for a minute or so?
Yes and the camera update. So far its freaking awesome.
Sent from my Transformer Prime TF201 using Tapatalk
As someone who is considering the Prime for purchase I would love to know if the ICS update helps or fixes the GPS and Wifi issues. Thanks!
Performed the update and all is well. Browser is WAY snappier. All-around performance also seems to be better as well but its hard to tell for sure. It is definitely not worse! Bookmarks did sync right away but it doesn't seem like I got them all. I'll check into it later - its almost 1am here! Doing camera update now.
I was worried about swype too - first time I used it it said screen res didn't match the swype package and to contact swype. After hitting okay to that it worked fine and hasn't come up again. So far so good!
My battery info still isn't showing. Hoped that would have been fixed.
Overall its world's better.
For some reason I had to factory reset to get the update to show up, but now that I've got it, it's pretty sweet.
Got the ICS and camera updates installed. It doesn't seem like much has changed (though it seems quite a bit faster) but there are more options in the settings menu and of course we now have the panorama option with the camera.:cool:
after ICS and camera update, my wi-fi will not connect- recycles at "obtaining ip address". Going into DHCP logs to find out what is going on
whew! false alarm- the phone went out when the cable guy came scenario. DHCP service on WHS needed tweak to allow the sec policy to pass and get IP address- all is good again.
brucestark2741
