ICS updated, no hack nor rom
Why does everyone think the *#*#682#*#* code doesn't work? I did it about 10 minutes ago, working fine. Make sure you're only Wifi. It gave no indication of working with wifi off, but when I connected to wifi and tried again it started within ~15 seconds.
I kept trying and after entering the code it would just disappear and I tried on wi-fi and connected to a charger and it never came up offering to download.
I just did it, I plugged it to my computer and dialed the number,it started in like 10 sec,and it took a while to install but its installed.
So I dont know if someone has noted this yet about the ICS Update, but.... I finally got it installed. And I was deleting something and noticed that it let me delete system apps, like AT&T Apps (Family.. whatever it is, Live TV, ect.) & it removes it from the All App area. I know you can Disable some also, but it actually lets you delete A few others. But I fugured i'd let you know incase no one else realized it yet. :D:confused:
Reactions: switchblade696
hermano disculpa soy nuevo en esto y en realidad no se nada.
queria preguntarte si ese codigo, uno tiene que marcarlo como una llamada o que?
o es de otra forma? y es para el htc vivid ?
Jackwills2567
