I'm having issues with LTE signal!
CHILLYWILL_95831
752
Since I've installed my January security patch, I've noticed that my LTE signal has gone away. Am I the only one?
I haven't received the patch yet. I'm in the USA. When did you get it?
My LTE signal has dropped as well some but for me and more concerning is my WiFi connection speed has really dropped. I noticed it right after I downloaded the January security update. Is there any way to revert back to the December patch?
December radio and January radios are the same.
Go to Google and download the angler images to revert back.
I am doing fine on T-Mobile. OP which carrier are you using?
I had the same issue yesterday. A reboot fixed it for me. Another option would be to toggle the airplane mode and see if LTE comes back.
No T-Mobile LTE issues after installing the January update.
Every time I leave wifi I am on 3g until I toggle airplane mode. In verizon.
I'm on Cricket and I've been noticing my 6p gets stuck on hspa+ a lot lately in strong LTE areas. As others have said, an airplane mode toggle fixes it. This seemingly started happening at some point within the past couple weeks.
Posted via the Android Central App (Nexus 6P)
I did a reboot and I suppose that worked while simultaneously talking with T-Mobile tech support. It all worked out and LTE band 12 is back on line.
I'm on Cricket and am seeing the same thing.
I was having WiFi issues after the Jan. Update... I finally did a factory restore and all is good again. Should not have to do that process but at least a factory reset is a simple solution. ....
I'm having the same issue on the ATT network! Phone drops to H+ in strong LTE areas. A reboot temporarily fixes it but then it drops again. I've toggled airplane mode of and off as well with no change. Thoughts??
alanmagdaong
