I'm trying to start from a scratch and install Community ROM 1.3..
Ok.. So if factory reset doesn't wipe out Sd card.. How should I clean it up? It looks annoying and I have no idea what all the folder are for.
SD card import/export does the same thing like misses the numbers! I mean I could add them everytime but who know what im missing. just gonna do backup assistant and hope that is better next time. Hopefully next clean wipe backup assistant will have them all. cause g contacts is f''ed
@ hecatic
Use Astro or a file manager and navigate to the sdcard. Erase anything that you feel is cluttering you up, that you know is not important. If your not sure, I would leave it there.
So I am on SC 2.9.2 right now. Should I flash ED01 package first then flash COMROM 1.3?
And do I flash COMROM from CW?
What ED01 package? You can just wipe your caches and than flash com rom 1.3 and all will be fine. It is recommended to wipe data, but some have had success without doing that. Just wipe your caches than flash 1.3.Com Rom 1.3 put on root of SD card and flash.
jobber. Did you get your contacts restored.. Have you tried restoring a nandroid and starting over?
Mr2Shorty3
