i'm using 3s prime? and there is a problem in notification bar.
ankit3302
13
hey everyone i'm using 3s prime and there is always notification bar on top side and shows download unsuccessful and it never disappear on my phone don't know why this notification is coming. Is there any solution?
What app is the notification from? You can try to long-press the notification to see which app sent the notification. Then go to Setting > Apps > find the app that sent the notification > Force stop. Force-stopping the app should make the notification disappear, but it may or may not reappear. Or you can also try restarting your phone to see if it will disappear.
ruhidubey0188
