Is there any fix without going full stock?
There is no reason not to go to full stock. I just want to see him have a fully functioning phone again and revisit installing a custom recovery and ROM later on. Taking it slow.
I'm not sure which the phone was shipped with. Should I do 2.2.1 to be safe? How should I go about putting .zips on the sd card if i cannot turn on usb sharing? just use my other phone to transfer like I was before?
You're better off doing the 2.2.1 for now, forget the 2.2.2 update. You can use ADB to push the file to your SD card, the command would be the following: (this will probably take a few minutes, just let it sit)
adb push (name of file) /sdcard/
although I'm wondering why you can't use USB storage?
