incoming calls when using apps
angeleyes
3
Is there a way to change something to allow incoming calls when using apps or online? they go straight to voicemail which is very annoying! would like the data to suspend and push the call through...is this possible?
Try going into Settings>Call Setting>Call Restrictions and setting incoming to Allow All. Maybe that will help?
Their is no fix for this because you can't and use voice and data at the same time on a CDMA network. This is only possible on a GSM (At&t) network.
Damn Dreya
