increasing sound volume
npark2012
516
Hey all. I just wanted to ask if there are any ways to increase the volume of the ringtones and such on my gnex. Volume+ isn't compatible with jelly bean and I don't have a rooted phone. Any work around on this issue?
You could always manually up the volume of the ringtones with a ringtone maker/editor.
There are probably other DSP managers or volume editors on the Play Store also. I don't use one though so I couldn't really make a recommendation.
Thanks for your response.
I will see if I can manually increase the ringtones in an editor of some sort. Thanks again.
If anyone else has any other suggestions please post!
I use speaker boost and it works great!
Rooting your GNEX and installing custom rom and using volume patch called NexusLouder might be the best option.
XDA has pre-packed rooting programs and detail instruction. All you have to do is download it, connect your phone to computer and run it.
I took that route and I'm really happy with overall volume level. I don't have precise measurement but it became as loud as my old Mytouch 4G.
-NexusLouder
[MOD] [GNEX] BEATS+XLOUDER! 4.1.1 [21/9/12] JB/AOKP Louder Audio Improvement Patch - xda-developers
-NexusLouder
Thanks but I don't want to root my phone.
rannypoker
