Incredible Battery Drain after Android N update
Feb 18, 2017
Hello Folks,
I really need help here. I am facing incredible battery drain after upgrading my HTC 10 to Android 7.0. It's on stock ROM with no root etc.. Everything stock. Including the launcher even. And honestly, I have uninstalled all apps and running pretty much vanilla. As per battery stats, Android OS is eating up 45% of the battery. I can share the stats in a while as I'm charging my phone up (2nd time in less than 6 hours). I have performed cache partition wipe, disabled WiFi scanning/optimization, disabled scanning of Location as well but still no go.
Can you suggest anything? I haven't tried factory wipe but I've seen people with similar issues having done that and still no luck.
I will share GSam battery stats soon. I feel my phone is useless in this state =(
After a large update it is always a good idea to do a factory wipe. If it doesn't help at least you tried and if you don't try you'll never know. I think poor battery life is one of the most common complaints after a major system update. Good Luck.
Before doing a factory reset... Wipe the cache in recovery mode... Sometimes that is all that is needed..
oval_clarity
