- Apr 27, 2014
- 2
- 0
- 0
Hi all, i'm sure the question has been answered elsewhere but sorry i'm not very good in searching and didn't find it...
the clock speed of the S3 varies from 200mhz to 1.4ghz.... i expected that, if you lunch a cpu-intensive app that brings the cpu load at a costant 100%, the clock of the S3 stayed fixed at the maximum... instead, i see (from cpu monitor / cpu-z) that the clock alternates speed between 1400mhz and 800mhz... it just continues swapping those speeds..... is there a way to let it fixed at maximum frequency of 140mhz ? power saving feature is off, battery temp is below 40C?, i cannot see anywhere in the S3 menu the option to do what i want... maybe there is not, or maybe only with rooting/hacking or similar things, that i don't want do to.... any input appreciated thanks,
