Infuse Car Dock Users
Wrong. Download Galaxy Dock Sound Redirector from the market. It will route your phone call audio to your car speakers along with your music. If you don't want your phone's ringer to blast your ears out, download Car Mode and your phone will ring through your phone's speakerphone instead of your car speakers. Car Mode does not launch automatically. You have to launch it manually and it does work with Car Home Ultra. If you want to use Bluetooth you can disable the audio routing in the Dock Sound Redirector app.
Thanks for the tip. Many of the reviews state that it doesnt route call audio through the 3.5mm jack. I will try and report back.
Funny thing after reading some of these posts.
If you had purchased the OEM car dock for the SPH-D710, our phone, then I doubt you would have some of these issues.
I have both docks, that cheaper Infuse dock and the one made for our Epic 4G Touch from Samsung.
The docks are definitely not identical!
There is a fit issue with the Infuse, that you may not notice unless you have the Epic 4G version.
And there is something different in the chip inside the Infuse that doesn't always go into the car mode correctly.
With the Epic 4G version, it switches nicely to pushing audio through the external speakers when you have the audio cable plugged into the back of the dock.
But you have to make sure you have that set in the settings page under dock setting.
Phone calls will come through Bluetooth headphones if you have those on. And all other audio goes to the external dock's audio port.
But I do like that Car Dock Ultra, I'm going to check that out.
Almost forgot, there is a break away clip on the back of the Epic 4G version a nice feature.
Rob
Rob sent this from his SPH-D710 via Tapatalk
First of all, whats with the double-spacing?! And secondly, My Infuse dock has NONE of the issues that you are experiencing. I get as an immediate start-up with Car Dock Ultra as I did with the stock car dock app. The fit has been fine, with small gaps in the corners. My phone has never dropped out. I even took pics of the gaps and posted them for others to see. I am perfectly happy with my $17 purchase (car + desk dock) and if this Galaxy Dock Sound Redirector works as advertised, then I have a perfect solution!
Unfortunately, this app does NOT route in-call audio through the 3.5mm jack. I downloaded and tried this despite the FAQ (first one) on the app's page and the many reviews stating that it does not route in-call audio through the 3.5mm jack. So either you have a custom ROM or youre doing something different because that app is not designed to do that. https://market.android.com/details?...xLDEsIm5ldC5tdXRlaGVhZGxpZ2h0LmRvY2tyZWRpciJd
Yes I do have a custom Rom. I use a cassette adapter plugged into my 3.5 mm jack and car stereo and I get in call audio through my car speakers and its freaking loud when my phone rings. That's why I use the other car mode app because I don't want phone audio through my speakers
AregbesolaOmot1
