Inspire Cases/Accesories
FWIW I emailed Otterbox and they said the Desire HD case would not fit the Inspire.
thats a bigger buzz then buzz killington....
im sure otterbox being a top notch case will step up once the phone is on the street.. shame it doesnt fit though. they look too alike for it not to.
could be a marketing ploy to prevent people from reusing cases and/or allowing them to up the price on brand new Inspire cases.
From what it looks like the 2 devices actually have different physical dimensions. So it may be likely that the Desire cases they won't fit correctly.
Hmm.....your right then. Desire HD specs: 4.84x2.68x0.46 Inspire: 4.83x2.7x0.46. I guess just enough to not work. lol :) *gives swift kick on own @ss* :D:cool:
May be an issue with Platinum Case for Inspire
I'm still checking this out but I noticed not long after putting the Platinum case I bought from BB on my Inspire Friday the phone started not switching from portrait to landscape mode when rotated. The only way to get it to do it was a complete power down. On power up it works right for a while & then stops rotating as it should.
I took the case off this morning & its been rotating correctly since. The case is very tight on the phone.
Anybody ever heard of this before? I'm new to this smartphone thing...
Will keep looking at this.
Shemp
Got my Inspire today. Decided to ditch a case and just go with a Zagg screen protector. Best Buy mobile only had the Platinum case that Shempster mentioned and one purple silicone case. ATT had no cases.
The thing is still working correctly without the Platinum case on it. I don't understand this. The thing is almost solid metal. How could a plastic case affect it like this? Shame, as I like the case...
Shemp
Shemp
The only thing I can think of is it's somehow interfering with the gyroscopic sensor inside.
I've got the Seidio Innocase II and a set of screen protectors coming tomorrow. I have a Innocase on my BB now and it's a really good cases and holster.
Screen will not rotate orientation
Shemp
Well, its not the case. After a power off all is well, but within a few hours of power on the phone no longer will change screen layout from portrait to landscape or vise versus. Going in & changing the setting does nothing either. Guess its going back to Costco.
Other than that I really like the phone.
Shemp
Reactions: pounder001
I picked this case up today from my local att. I like it a bunch.
* Hard shell. Soft center. Sweet Looks... two layers of protection seamlessly combined
* Glossy hard shell exterior for impact protection.
* Soft rubbery interior lining for shock-absorbing protection.
* Top and side button covers.
* Raised front bezel lip prevents the screen from touch flat surfaces.
* Patent-pending one-piece design.
* Compatible with HTC Inspire 4G.
Is it difficult to get into and/or out of your pocket? In other words, do the exterior grip the fabric a lot, or does it seem to slide pretty easily?
ecomranx32
