installation of screen protector
Same with me. They also sent a spare for the phone I replaced with the S8 :) They do support their customers.
Interesting because it's been 5 days and I haven't heard a word from them. So as far as I'm concerned I will never spend another dime on any thing of theirs. Armorsuit is a garbage company as far as I'm concerned.
Call them, I did. I had very little confidence in them responding to my email. I now have a replacement screen protector on the way.
I put liquid defender on my screen or whatever. Used it on my note 7 and S7 edge and never had a scratch. Using it now on my s8 (just applied about 18 hours ago. Takes 24 hours to fully cure) and haven't had any problems.
Had a neoflex on it and got tired of the weird rubber feeling and edge of my nail snagging on the screen.
Looking into getting the white stone or dome or whatever protector that comes with a bottle of glue lol.
Also, as much money as I might spend just trying to find a screen protector, might as well say screw it and pay deductible if it breaks.
I just installed a case friendly spigen screen protector. (Comes in a 2 pack). I installed it (this morning) with my spigen case installed. So far, no complaints and it looks good!
What protector is it? I tried neoflex
I just ordered a screen protector from Ringke. It has really good reviews. It's designed so that it wraps all the way around the edge of the screen to the back of the phone. That way a case shouldn't peel the corners off.
Galaxy S8 Screen Protector, Invisible Defender [Full Coverage][2-Pack] Edge to Edge Curved Side Coverage Guaranteed [Case Compatible] Super Thin HD Clearness Film for Samsung Galaxy S8 2017 https://www.amazon.com/dp/B06Y999MW...ag=hawk-future-20&ascsubtag=UUacUvbUpU5816252
But cases might be tricky even after they 'stick'.
I had trouble with my "case-friendly" Spigen screen protector.
Spigen told me to install it with the case on.
No issues after using that method. I had to keep pressing the edges down but they're sticking now.
I really like my Yootech wet install, the only problem is it peels on the corners with lots of cases.
Does anyone have any tips on how to actually get the edges of the screen protector to actually stick. I'm currently trying g the yootech which has amazing reviews. After sitting for 2 hours all the edges peeled back up. I have tried others and the same thing. The edges won't stay stuck down at all.
I'm also aware that I started the " why are screen protectors still a thing thread" I listened to the arguments and figured what's the worst that can happen. I would like to actually try one out but the darn edges won't stick down for me.
Try the original one from Samsung. That one has very strong adhesive.
I tried that Spigen case friendly and after 4 attempts (they sent me a replacement) I gave up on that pile of crap. The funny thing is I am using a Spigen case. I actually had one last ditch effort and gave the IQshield a shot and it worked out very nicely. There isn't as much edge over lap unlike Spigen. It sits perfectly at the very edge of my case. It went on nicely the edges went down nicely and stayed down.
I still have my Yootech on right now (corner peel and all), but my iQShields came yesterday so sometime this week I'll probably try it out.
Posting in this thread so I remember to check it out later. I need to order a new screen protector. The one I got from Sprint is lifting on the edges as well. Still leaving it on though. I'm curious about that Invisible Defender that wraps around the edges to the back. Hm.
Not Prime. I generally don't buy non Prime items because I feel there has to be a reason why it's not Prime. Inferior quality, bad vendor... I dunno it just raises questions to me and I'd pass on that due to not trusting that vendor. Also, be sure to look for Verified Purchase on the comments or else I'd consider them fake reviews.
I just noticed it looks like lots if not all of the reviews for this are Verified Purchases. Looks good to go! I still wouldn't buy due to being a Prime Snob though lol.
I have the yootech installed on mine. If installed properly it is a beautiful screen protector. It came in a two pack and I messed the first one up trying to install myself. I didn't want to take a chance and got it professionally installed with the second one. It looks great but after about 36 hours I kept it in the bathroom with me while I was showering and I think all of the moisture of the shower steam put a bubble in it. I took it back to the guy and he fixed it for me and it looks perfect again. Going to wait a little longer before I keep it near the shower.
rosemar3
