Insufficient Storage Error
OK this just occurred to me. I wonder if this had something to do with it.
I recently updated to the newest Stock HTC OS by installing a ROM using CWM. However i didn't do a data wipe before hand. Could this have something to do with it?
It says 1.1 GB used and 58 MB Free
That basically seems to indicate that you truly have 1.1GB apps installed!!
How many apps do you have installed?
The top 5 apps you listed add up to about 77MB. That means you have about 1050MB of other apps besides that - even if they were 10MB each, that means that you have 105 more apps installed.
If you really have over 100 apps installed, and they are all residing on your internal memory, there really isn't much you can do besides uninstalling some many of these.
If you don't have these many apps, you might want to go thru' each app to see how much that really adds up to (sorry, I can't think of an easier way of doing this - maybe others have better/easier suggestions)
OK so i re-flashed the OS, but i did a full data wipe prior to this. After everything was all said and done, i have over 700 MB free. So that was the problem. I had flashed another ROM without doing the data wipe.
Help77
