Internal Storage Full!?
Hi All
The bad thing is until the phone is rooted there is very little you actually have control over. the best is to root the phone get a app that can see into all storage's like "X-Plore or BlueFTP" then go searching for those pesky hidden system self created space eaters like thumbnails and so on. Also with android 4.* the phone doesn't have wright permissions to the SD Card therefor creates a dummy SD Card on the internal for writing purposes. rooting solves this and makes the SD writable. (DON'T TRY AND DELETE DUMMY SD BEFORE ROOT).
Re: can't use my full internal storage
I cant use my full storage which is suppost to be 16GB i can only use 9GB of it and everytime i download a small amount of byte it says it is full. I neef help. Thanks
jenleasch12683
