internet stoping,and going back to dashboard?
Ok, cleared data from manage apps not from the browser settings. Disabled JavaScript and flash player via the browser settings. It seems way better. Only crashed once and I think that was just me overloading it to quickly. Haven't tried it on the tablet yet though. If you Google android browser crash, it seems this has been a problem for a while. I know that doesn't explain why we all had our issues now. Hopefully it continues to perform properly.
Somethings definitely up........glad I'm not the only one.
Cleared cache, cleared cookies, went into developer options and disabled animations, changed search engine from Google to yahoo, used dolphin, checked and unchecked data usage limit, and YES I did the dreaded factory reset, even called Verizon and as usually I helped them with their phone more than they helped me........
Still crashing on certain sites. I will continue to update. If anyone figures it out please post!!!
Sent from my SCH-I535 using Android Central Forums
Re enabled flash player leaving JavaScript off. Still no crashes. Looks like java has something to do with my issue.
Thanks for the info. Same thing here. Must be Java. Now no crashes....
Here at best buy with a sales rep and Tryed the java thing and it worked! Try it and let us know if it worked for you.
Downloaded Chrome as my browser. No more crashing. I like it better too
yeah been happening to me on and off with the stock internet browser for a while finally just switched to chrome and problem is gone
Stock internet still working just fine after unchecking JavaScript in settings. Hope it holds!
dumpsterrentals85
