IPAD Charger or Kindle Fire Charger
Is it OK? Im not 100% sure what the answer to that is. But, between those two choices you should choose the iPad charger. Apple over-engineers their chargers for safety. I used an iPad charger pretty much the entire time I had my S3 and never had an issue. Also used it for my iPhone 4 and Note 2. Never damaged a device and charged it really fast.
Check the output on the chargers. Volts (V) and amps (A).
With any transformer, if the Volts and amps are equal or below your device input, you are safe. (Safe for the most part, depending on the quality of the transformer.)
If they are below, charging the device may go slow or not at all.
I'm using as iPhone charger if it helps AHAHAHAHA
Sent from my SAMSUNG-SGH-I337 using Android Central Forums
