Is 16gb really enough?
Thanks guys a lot of you helped me out..I have a 32gb ipad but getting rid of it i want a galaxy note 10.1 was wondering if 16gb for apps alone was enought...movies and pics all that stuff can go to sd card but im an app fene lol.
If you like to play a lot of heavy duty games, some of them can have 3 gigs of data. When I first got the S3 I bought Batman in the play store just to check out the graphics on the phone, (which are absolutely amazing). Anyway, I was stunned to see the game took about 3GB of space after I downloaded all the additional data. 3 or 4 games like that and.....
Just something to keep in mind.
I think if you're a serious gamer, you need to look at the 32GB version. For the rest of us, 16GB is probably fine, since you can put all of your media files on an external SD card.
Yea, No. 16 is nt enough, but i must admit that, all it took was going to the store and dropping 23 bucks on a 32GB sd card and im set....
Just as stated above, if you're becoming a phone gamer like allot of people 16GB is no longer enough internal. Especially since these games won't allow moving off the internal sd. And the apps that will allow rooted users to swap internal and external and make virtual folders, etc are confusing and risky. Just in the descriptions alone.
Anything else can be moved to the sd card. I personally use an app called foldersync that I use to automatically move downloads, etc to the sd card. Keeping it off the internal.
For the streamers out there like myself I use Google music when in 4g and Wi-Fi but I also have my music converted into 64kbps mp3 files and stream them from my dropbox using the app "cloud around". Simple set up(force closes on 1st scan if you have allot of music but after that beautiful). I found that at that. format it streams even over sprint 1x(can't get worse network condition than that) and a equalizer to replace the bass loss from converting down the files it's not bad.
DonJrPlayz1234
