Is Gsam Battery Monitor supposed to take a long time to calculate charge times?
Chaumander
4
I tried searching for threads about this, but couldn't come up with anything.
I installed Gsam Battery Monitor on my new Droid Turbo, and opened the app. I waited about 10 minutes and checked the calculating status, and everything was still calculating. I went ahead and cleared the cache/app data hoping that would help, but after opening the app back up and waiting 30 minutes, nothing has changed... Is this normal? Something wrong?
Any help would be great! Thanks.
When I installed that app, I had no such problem with it. Is it possible you have some other app on board that may be interfering with its normal function? Failing that, it may be worth uninstalling and re-installing.
