Is it beyond help?
CNoble01
I have a Galaxy Tab 2 10.1 that just decided to stop working, every time I turn it on it goes through the original set up procedure but gets stuck at the point where it states "This tablet belongs to..." I have carried out a Factory Reset with the power and volume buttons but it gets stuck at the same pint again, can anyone help me get past this or is it beyond help?
If you have access to a windows pc try flashing a standard rom {operating system) to the tab.
Here is a guide for 4.2.2. If you need 4.3 do a search on Google for the same terms just change to 4.3 or 4.1.2 as required.
Well Google wants to recommend and recognize who is the owner of the Tablet, but you can past it try setting it up to the forward button or think about bypassing it.
Posted via Asta Galactic Center
