is it me or i Type with no Mistakes with iPhone Keyboard then with Galaxy ?!?!!!!!
I had this problem this morning. Was typing a FB status in my parked car before I went into work. The keys stuck together when typing. It was like I was typing faster than it could process. No problems right now, in a building. Maybe the phone or my fingers were cold.
I can type decently fast wit the stock keyboard, but I really prefer SwiftKey.
try the New google keyboard and goto Material Light and try it. I have note 4 and 6+ and I type just fine on the Note using that keyboard.
I will admit that apples keyboard is slightly better. but the material keyboard works great on the note 4
I think what you are experiencing is the auto correct portion. Apples auto correct is 100 times better than androids.
I use the microphone and talk to text. If you speak clearly, it will work just fine 99% of the time. Typing stinks.
any other android phone you recommend before going back to iPhone?!
One of the many benefits of Android is there are many 3rd party apps that can replace core apps. As others have said, try one of the many other keyboards available. You shouldn't have to change your phone.
3 month is not enough to get use to...?
If you have been using iPhone for years, quite possibly not.
Funny I've had the note 4 since launch and I've tried fleksy and Google key board. For me the best one is honestly the stock one. I do have typing issues though as well. Annoying but I deal with it. Sometimes it types stupid things that make absolutely no sense when I got most of the word right. Like for some reason I'll type get and it'll correct it to grt and then I'll have to remove it from the dictionary. Unless I told the iPhone to Erie grt it wouldn't. I wish there was a way to press the little x on a predicted word like on the iPhone.
Fleksy has the swipe up to change the word it corrected 😊
Been using TouchPal. Better than swype and has handy/quick options such as swiping up from top row to get #s, and prediction is pretty solid...
I think so much if this is what you are used to. I went from blackberry to ios to android. The ios keyboard is by far the most frustrating for me even to this day.
For the note 4, I am still using the stock, but I have used Google's, swype, and swift key extensively. Swift key has been my favorite for a while, and I will probably put it on my note soon.
Sent from my SM-N910V using Tapatalk
If you want to use the S Pen for text input, yes.
As far as handwriting to text input goes there's two ways to do it when stock keyboard is used but you lose one method when you change the default keyboard (the one where you're writing on a line that scrolls).
Sent from my SM-P900 using Tapatalk
That's the method I meant... writing on the line that scrolls. How else is it done?
so i have sold my note 4 today.... and thinking to buy an iphone 6 plus.... what you guys think?
any other recommendation for a similar sized note 4/ iphone 6 plus phones.............??
Well, if that works best for you. While I like my iPhone 6+ a lot I absolutely love my Note 4. It is almost perfect to me. The 6+ hardware is fine but iOS has less to offer me than android. If, however, you really want the sliq simplicity of iOS then you might love the 6+.
from the cutting Note Edge 🔪📱
what are you missing with iOS for example...?
The ability to change fonts, change icon packs and layout, use a file manager to name a few. That's just android in general, not Samsung's niceties like replaceable batteries, SD cards, and the almighty S Pen.
from the 🔪 Edge📱
Tdoperfdu
