Is it my problem or Verizon/HTC
With all seriousness, you need to be banned from all electronics. Either that, or the DYFS equivalent for abused electronics needs to be called.
What I did with this same problem was instead of leaving the phone in rice for 3 days, I used ice cream. Then I got a good charge on my battery by sticking it in my mouth then while standing in some water, I stuck my fingers in a hot toaster. Works like a charm.
Sent from my ADR6400L using Tapatalk
Reactions: MR.Sunday Morning
Lol this is the most ridiculous thread i ever read
I cant believe the lengths you are going to in order to avoid buying another battery for $20
You already washed a $550 phone then instead of buying another battery to try that you cut a usb cable and touched bare wires to the phone contacts? It seems like you are not sure if the washer destroyed it fully so you want to really finish it off now
If you dont wabt to buy a battery take the phone to the store and see if they have one you can try
Then call and do an insurance claim because your phone is done
Tiokujha
