Is it possible to connect my Gear S2 with a Note 3?
  • Start date Start date
A
AC Question
is possible Gear s2 connect with note 3
I paired my note 3 with gear s2 by samsung gear application ,
But notification not displays on gear.
For solving this problem contacted samsung helpline (smart tutor app )also.
But the result is same.
Have any soloution?
By: shihab.m
Re: is possible Gear s2 connect with note 3
Have any soloution?
By: shihab.m
Android Compatibility
The Gear S2 is compatible with most AndroidTMdevices,1*letting you in on the amazing Samsung experience.*
1Compatible with select devices using Android 4.4 and later with at least 1.5GB RAM. Supported devices may vary by carrier and device. Some features may not be available. For best results, connect with compatible Samsung Galaxy devices.
1) I'm guessing your Note 3 is running 4.4 or higher
2) You have the latest version of the Gear software?
3) Depending on who your carrier is, might be the issue
4) If on AT&T, you do know that Number Sync will not be available to you because of your Note 3.
bigofof571
