vzwuser76
- Jan 28, 2011
- 1,669
- 26
- 0
My point exactly. So why in the world does the iPhone have a bigger battery (albeit slight) than the Bolt? Shouldn't it be the other way around?
Sent from my HTC Flyer P512 using Tapatalk
Part of your question was answered in the message you are replying to. Because of the smaller internal components in the iphone (screen, 3G radio) they are able to put a larger battery in a smaller frame. Have you looked at all of the LTE phones being released on Verizon? They are all pretty big. That's not just the 4.3" screen. Look at the Tbolt, Charge, or Revolution. They are all much bigger than the Droid X which has the same screen (and does good to great on battery). It has to do with the LTE chip. The larger screen just compunds the issue.
You are correct that they wouldn't have to have a battery tray with a nonreplaceable battery. But that will probably only net you around .25mm either way. That extra space is not going to gain you an extra 4 hours of use. The slim extended batteries, even if they are OEM and have an additional 300mAh net you an extra hour, maybe two.
That is IMHO the real reason why apple hasn't introduced an LTE phone. I read last year that they are working on battery density (getting more mAh out of the same physical space). I don't think the driving force behind that is to get more power for their 3G phones. It's to be able to power an LTE device with a nonreplaceable battery.
I also agree with what someone said earlier about they don't want a user replaceable battery so they can charge you to replace it or upsell you on a new device. But more than that, if they did make the battery replaceable, then you'd have what all other phones have. Many different manufacturers selling replacement batteries. Apple doesn't like to have non approved parts or accessories going into their devices.
I've had a few ipods in my time and one thing every one of them has had in common. After the initial 12 month warranty period, the battery needed to be replaced. I got the extended warranty on my first one because I was shelling out quite a bit (at the time) for the device. After I had the battery replaced on month 16, when I got my next ipod I put the extended warranty on it. That one had to have the battery replaced on month 15. And such was the case with every other one I have had. I'll agree when the battery is fresh, they get great battery life (firends with iphones/ipods as well) but after awhile they go downhill & need to be replaced. I've never known anyone who hasn't had their battery replaced in an ipod/iphone who had it for any amount of time.
