Is there a Guide for using Toolbox in Mybackup Pro?
rando991
588
30
TOOLBOX Freeze Questions--NOT Backup questions:
1. When I try to freeze/unfreeze apps in MyBackup Pro Toolbox, only the first app completes and the progress bar on the pop up screen just sits on the first app checked (50% 1/2 for instance) and I have to back out. Do I have to INDIVIDUALLY freeze and / or unfreeze every app?
2. Also, why is there no guide to using the toolbox? Shouldn't there be a master list you can view that tells you what apps are frozen? Does Titanium Backup have a solution to these 2 questions, (before I buy another one).
Re: Is there a Guide for using Toolbox in Mybackup Pro???
I'll answer my own question...
1. Doesn't work the way it was designed, despite uninstalling, rebooting, reinstalling, running from phone or running from SD card.
2. no there is no guide yet.
Looking to try our Bloat Freezer next...
Diluoyha
