Is there a way for Auto Replace to not insert contacts' email addresses?
JanShim
67
I am using the stock keyboard and auto correct functions. Every time I enter someone's name Auto Replace thinks there's a match against Contacts and suggests their E-mail addresses as replacement. The E-mail takes up the entire rectangle and I have to tap on the arrow on the right side to ignore or look for other words to use. Is there a way to configure the Note not to ever look up contacts at all?
If you hold your finger down on it, are you presented with an ignore option or something?
A 'Remove' pop-up screens asking if I want the learned word (in this case, an e-mail) "... will be removed from learned words." This method just means I would have to individually unlearn every (other) email it suggests.
shronlndry
