Is there a way to put my iTunes on an Incredible?
I use iTunesAgent. Simple and works well in my experience. Doesn't sync playlists though.
I'm still on a BB Storm1 and am considering making the switch. Do I understand this right, the native Media Player does not play .mp4?
Doubletwist should work but you can try Motorola Media Link from their website. It was updated not too long ago and as far as I know can import playlists and music from itunes.
It does, I am watching an episode of BSG I ripped from my DVDs using Handbreak on my Inc right now. It won't play DRMed MP4's though, as in anything bought from the iTunes store. Same goes for music.
iTunes Agent 1.3.1, google it, there is a "how to" online, it allows you to use your internal 8gigs and your microSD slots as removable drives, you just create a folder in each of them (i.e. Droid F, Droid G) then you open iTunes, it will pick up those two folders and you just drag and drop what you want from your itunes library into them as if making a playlist. When done you right click on the taskbar icon and choose to sync. The whole process takes roughly ten minutes or so.
Do either of you know if you can transfer movies that are bought on Itunes the same way to my DINC?
I would assume so, but wanted to know before I spent the $$ for it. Feel free to tell me of another(maybe easier way to do it as well.)
I just went from Double Twist to iSyncr. It is much better. A lot easier to use and better interface with iTunes. Double Twist is extremely slow when you have over 40gigs of music. iSyncr does add album art too. You can add videos and podcasts from iTunes also. I think this is a keeper..... at least for now.
Anything you buy in iTunes (movies, music, etc...) isn't going to transfer to anything other than an Apple product... unfortunately, Apple has DRM (Digital rights management) cooked into everything it sells and won't play nice on non-apple devices. I'm sure you can google how to find ways around that though... ;) (I did.)
I am using iSyncr to get movies, podcacts, and music on my Moto Droid right now.
As far as movies, this is probably true. Not true for most music sold nowadays. Apple has been moving to non-DRM music (still aac based) and with a higher bitrate (256) than before (128). Most of my previously purchased music was able to be upgraded to the new format for an additional fee ($0.30 each song I think)., and those non-DRM formatted songs play just fine on my Nexus. But it is a pain in the rear trying to get iTunes playlists, etc., transferred over. iSyncr seems to work best for me, but I'm still getting empty phantom playlists, etc. Don't know if I should just start from scratch in iTunes or another music manager, but hopefully I'll have time to look this weekend sometime.
+2 for Isyncr.
It became my 3rd paid app (after BetterCut and WeatherBug). Well worth the money. I tried DoubleTwist (ugh, slow and nothing but errors for me) and TuneSync (neat concept, but troubleshooting the connection sapped my energy). Isyncr is cheap, and it just works...flawlessly.
Try the free version (that's what I did). It is awesome. After that, it is SO easy to change playlists now. And it is fast.
my two cents.
K--
Veronicauliet
