Is there an easy way to report problems to google on Nexus 4 ?
Niloofar6
Active member
Jun 28, 2013
35
I'm using a nexus 4. And I can't find anything like a support application where I can share my problems! it is usually located as a app called "support" in other phones! Is there any trusted and easy way to inform Google about my problems? Like errors in stock apps which doesn't have a "feedback" option themselves, or errors I'm experiencing after updating to 4.3 Jelly Bean. There should be a way to inform them and get responses!:-\
If an app force closes there is a "report" button that'll let you tell Google/Developer about it. It pops up when the FC window does.
If something isn't working on your phone the way it's designed to you can call up or email Google Play Support and they'll try to address the issue.
Something that is functioning as Google designed it to function isn't a bug so I think the short answer on why they don't ask for feedback on how Android works because they don't want it. I know that's a bit harsh but Android is open-source. If you don't like how something works, change it or install a ROM that changes it for you.
Your best bet is probably going to be to post your problems here. Lots of smart people float around these forums and most love to help out.
webdesigner
