Is there any way to fix my phone when it keeps not typing what i am typing?
  • Start date Start date
A
AC Question
I have a Samsung galaxy mini 2 and it has been in repair twice already. Every now and then i am tryping and then it stops writing it as it its not responding.
Welcome to Android Central! Does it freeze up for a while, or does it just pause for a bit? Does the rest of the screen register touches?
Try booting into Safe Mode, which prevents 3rd party apps from starting up initially. If that behavior goes away, then something you installed might be causing the problem. Start opening your apps one by one, and check the typing after each app start, to see if the problem recurs. Steps for Safe Mode are here: How do I start my Samsung Galaxy Mini 2 S6500 in Safe Mode? | MobiWhy
KidColoringPage
