Is there any way to sort the app drawer alphabetically?
Hi, I just received my edge yesterday nd had thr same issue. I Googled it and what I found worked though it's time consuming and you shouldn't have to do it this way. Go into the app drawer and click edit then hold each app and drag to where you want it. 😊
Re: Sorting the app drawer and moving icons
Good old fashioned elbow grease this one. Go into app drawer hit EDIT in the top right hand corner if the screen and manually drag and drop each app where it needs to be to achieve alphabetical perfection. Takes rkme but its quite fun as you get to know all your apps
Same issue on my Galaxy s5 there's no app drawer menu that will let me sort the apps (including the wrench at the bottom) UNTIL i accidentally swiped up on the far right and it brought up the menu (same as 3-dot was)! I hope that works for you too!
Open the app drawer, go to the last page where there's some open space and swipe up. Granted, I'm using Go! Launcher, so it may only be an option for that. Hope it helps!!
miyonfaga
