Isn't there some sort of audio media effects/equalizer on the GN?
greydarrah
3,047
222
I thought I remembered reading a thread here about an sound equalizer type app that came with ICS, but I can't seem to find it on the phone. Does anyone know if it exist and if so, where it is? I don't even see the Media audio effects in the Sounds section of the settings.
Re: Isn't there some sort of audio media effects/equalizer on the
I was wondering the same thing. It would be great if someone who's found it could let us know how to get to it.
If you use Google Music, yes. Don't know about any other players as I don't use anything except Google Music. It's under settings while your song is playing. Appears to have full equalizer.
Reactions: greydarrah
Thanks. I appreciate it. Google Music is all I use so that will work perfectly.
So I'm noticing the the default settings seem to have the bass pumped way the hell up, to the point it sometimes drowns out the rest of the music I'm listening to. I use Slacker mostly, and didn't encounter this problem on my old OG Droid. Does anyone know of any good global EQs that are GNex friendly?
How do you control the bass boost or 3D effect setting? The options are both faded out for me.
Couldn't find it either, I downloaded an equalizer app for that.
The app I downloaded didn't allow the bass boost you're talking about either.
Try Volume + (it's free from here: Downloads | AndroidAudioHacks).
